Hi There,
I hope someone can help me with this:
I just bought 2 tracks from hardstyle.com.
The tracks are both in wav format, but one of the tracks only gives noise.
In Winamp and Wmp it plays perfect.
I also checked it at a friend of mine who has Vdj 5.2, but also the same problem there.
Is this a known issue and is there a way to solve it or should I contact hardstyle.com?
Thanks for your help.
Regards,
Trblnz
Regards,
Trblnz
geposted Mon 12 Oct 09 @ 2:42 pm
Burn them to a cd.... And then put into your cd-rom... Open VDj or numark .... And convert to mp3 and bam...!! Also you can do this with iTunes song mp4 cuz if you record your mixx's it only does mp3 ....!!!
geposted Tue 13 Oct 09 @ 3:21 am
But I buy tracks in wav format because the audio quality is so much better than mp3 and Vdj should play wav audio files as stated in the manual.
So i'm not buying wav tracks (expensiver than mp3 tracks) just to convert them to mp3 format to play them in Vdj.
geposted Tue 13 Oct 09 @ 10:16 am
I agree. Why cant VDJ play wav files well consistently? Winamp does, WMP does. I used to ba able to play wav files fine, but recently some error code or sound awful. What gives?
geposted Fri 11 Dec 09 @ 10:37 am
