ok 1st question.been using 6.1 for ages now and thankfully no problems.but last week in browser had no old files noe it says i have 166 old files.i have moved some songs around in folders ect but not sure wheter to clean and fix in case i loose songs.
database question.have currently 3 different versions of vdj on laptop and want to know if i can share databases from 6.1 with the others incase i need to use them.
thanks in advance
thanks in advance
geposted Tue 13 Oct 09 @ 3:25 pm
have you renamed any mp3's/files?
geposted Tue 13 Oct 09 @ 3:27 pm
yes charlie some where spelled wrong and some was missing info
geposted Tue 13 Oct 09 @ 3:32 pm
Are I see, they will show as dead links then and you should clean your data base to get rid of them.
Don't want to advise on second question in case I completly fuk it up for ya
geposted Tue 13 Oct 09 @ 3:40 pm
great charlie ta just didnt want to loose any songs.also do you know if i can share databases
geposted Tue 13 Oct 09 @ 3:42 pm
I don't could do with knowing myself as I have two also
geposted Tue 13 Oct 09 @ 4:37 pm
lol cmon tech guys help us mere mortals out
geposted Tue 13 Oct 09 @ 4:39 pm
Wow... I didn't realize 6.1 has been around for ages.
Have you tried 6.2? It was just released 10 minutes ago... go get it before they sell out!
geposted Tue 13 Oct 09 @ 6:51 pm
only have experience on ehd staffy, all the info for vdj to read is stored on that, now when a new version has been introduced, you will notice that a lot of the information is missing in the browser, this will be picked up by vdj and you can see the count decreasing as vdj recognizes the files, to the right just above the browser line by the two bullseyes depending on the size of database, plus you will see the files in the browser info filling up as the count decreases, well thats what happens for me, might have a bit of the info skew wiff there but it is 2am.
geposted Tue 13 Oct 09 @ 8:00 pm
djreene inhavent updated because im having no problems at the mo as they say dont fix whats not broken lol
geposted Wed 14 Oct 09 @ 5:18 am
The answer to your dilemma is that every time you make the slightest edit to a file outside VDJ you lose the file link, including but not limited to a period, so you will lose the link but not the file.
1. Go to the folder that you edited in from in VDJ (Left Panel Folders) highlight it.
2. Right click and chose add to search database.
3. You will find the edited file in your browser, then just delete the yellow dead link.
4. If the song is part of a saved playlist then you will have to replace it with the new file and resave effected playlist.
Good Luck
Joey....
Good Luck
Joey....
geposted Wed 14 Oct 09 @ 10:23 am
