I just purchased NI Audio 4 DJ sound card. In Virtual DJ, I don't see a "low latency/ASIO" option available. Only Simple and 4 Out card. This doesn't look like it's using an ASIO driver. Am I doing something wrong?
geposted Fri 16 Oct 09 @ 2:58 pm
Hi,
Asio did not exist on Mac OSX.
It use core audio instead;)
geposted Fri 16 Oct 09 @ 3:18 pm
Ok I see... Is it still low latency?
Is it possible to use the headphone output on the Audio 4 DJ using Mac VDJ at all?
geposted Fri 16 Oct 09 @ 4:34 pm
Hi, i do not have the audio 4 with me.
You can add it as an aggregate devices and use it. I should think the headphone should work there.
Perhaps somebody with the card can advise you more. Nevertheless i try to find out more on this.
Kind regards;)
Kind regards;)
geposted Fri 16 Oct 09 @ 5:39 pm
Yo can u post if you get it to work!!! Idk What interface to get I was thinking about the audio 4 dj but wasn sure if it would work. Im also using a macbook with snowleopard ( rite interface is wats keeping me from buying the program)
geposted Sat 17 Oct 09 @ 5:37 pm
Hi Dj Rollz
Yes, it works great. I had my first gig with it last night. Sound quality is good. No problems so far.
I just wish it had customization in control panel.
geposted Sat 17 Oct 09 @ 7:59 pm
Great to hear that;)
geposted Sun 18 Oct 09 @ 8:51 am
Hello, we have in Germany any people, they have many problems to config Audio 4 with TC. They have no Signal or bad sound.
Do you have a Video or describtion to solve the problem?
geposted Mon 19 Oct 09 @ 3:43 am
Sorry, I don't use TC. Maybe someone else can help?
Also I don't notice any change with different latency settings. Is it really using low latency?
geposted Wed 21 Oct 09 @ 10:13 pm
So does anyone know if this card works with Time Codes?
geposted Thu 05 Nov 09 @ 12:32 pm
