Hi,
does anyone know how I can save the cue points so that they remain even after I've closed VDJ?
Thanks
Xavier
Thanks
Xavier
geposted Sun 18 Oct 09 @ 6:47 am
It's automatic...
geposted Sun 18 Oct 09 @ 7:19 am
dude it's not automatic when i close vdj and then open it again the cue points are gone
geposted Sun 18 Oct 09 @ 1:18 pm
Try to fix your database by pushing FIX button in Browser window.
geposted Sun 18 Oct 09 @ 1:41 pm
Using which OS?
geposted Sun 18 Oct 09 @ 1:48 pm
In which case you have a problem; I can assure you it is completely automatic.
As above; what OS and what VDJ version? Does VDJ close cleanly or is there any kind of crash?
geposted Sun 18 Oct 09 @ 5:29 pm
Do you ever change your file names or move the files around?
The cue points are relative to the file location.
I maintain a folder of for charts and each week change the track number to the chart position and then get MediaMonkey to rename the files. Consequently when I open the chart folder again all the cue's are gone. I accept this for these folders, but for the rest of my music cue points remain with the tarcks...
The big issue I have now is that I've been going overboard on Media Monkey (which I only discoverd a few weeks ago) as I have been renaming files the way I have always wanted to <disc#><track> - ... This means I now have a fair few tracks that have changed which are about to loose all their cue points etc.
I was thining about writing some code to transpose the filename sin the database, but that would probably take a lot longer than simply resetting the cue points when I load the track!!!!
Cheers,
Roy
Cheers,
Roy
geposted Mon 19 Oct 09 @ 3:39 am
hey, no that didn't work but thanks anyways
geposted Mon 19 Oct 09 @ 6:41 am
spinnaJ wrote :
Using which OS?
hey I use osx version 10.5.8
geposted Mon 19 Oct 09 @ 6:43 am
yes it closes normally but when i open it again i have set the cue points again
geposted Mon 19 Oct 09 @ 6:45 am
Hi, you have to set permission for your vdj folder.
Look at the given link. It have been discussed numerous time. And also it will be better if you post it at the mac forum. It is a forum to cater for a mac user like you and me;)
Read here
Best regards;)
Read here
Best regards;)
geposted Mon 19 Oct 09 @ 6:49 am
Read here
Best regards;)
Read here
Best regards;)
Hey it completely solved it :) thanks a lot man!
ok next time i'll post in the mac forum
Xavier
geposted Mon 19 Oct 09 @ 7:26 am
Good. Nice to hear it;)
Topic moved from general forum.
geposted Mon 19 Oct 09 @ 8:46 am
