Computer specs
AMD Phenom X4 9600 quad core 2.30 ghz
ASUS M3A78 mother board (green)
8 gigs of OCZ Fatality 1066 DD2 dual channel ram
Video card EVGA NVIDIA GeForce 8500gt 1 gig
Running VDJ 6.02
I have windows 7 ultimate (64bit) on my computer. For the foremost it runs great but when I do video mixing on VDJ it keeps freezing. I have tried all day yesterday to fix the issue. Messing with the video card settings and messing with the videio settings in VDJ. Nothing seems to work.
I know it is still early to ask this question since windows isn't launching 7 until next week but if any of you have any suggestions on how to fix this I would appreciate it.
Running VDJ 6.02
geposted Sun 18 Oct 09 @ 11:16 am
I had a similar problem while running my vista 64 bit, when I first bought the software. It didn't freeze but the fade effect would not work correctly when mixing the vids. The screen would just blink in and out until the mix finished.
I resolved the problem by switching my skin to the VideoVision 6.
I dunno why that fixed it but it did. Worth a shot.
Hope that helps,
DJ James
Hope that helps,
DJ James
geposted Sun 18 Oct 09 @ 11:57 pm
I had the same problem running the 32bit version on the RC Client. I was told at the time it may be due to the video drivers not supporting Windows 7 @ the time. I will go to 7 this week the RTM drops this week. Hopefully the drivers will be supported by now.
My Laptoip specks
Toshiba Satilite
2.2GH Core2 Duel
3Gigs DDR3 Ram
250 x 2 HD running 7200rpms
Nvidia 8800 GPU
Windows XP (will be 7 in 1 week)
BTW VOODO You never got back to me? what happened?
My Laptoip specks
Toshiba Satilite
2.2GH Core2 Duel
3Gigs DDR3 Ram
Nvidia 8800 GPU
geposted Mon 19 Oct 09 @ 11:45 am
