Hi all,
I just want to check before I re-install Virtual DJ that I do not have to back anything up or save anything.
I am 99.9% certain that uninstalling 5.2.1 will leave all Virtual DJ folder intact and a frsh install of v6.0.2 will pick everthing back up again.
The only thing I need to do is re-build my database which v6 will do automatically...
For some reason I'm nervious about this...
Roy
Roy
geposted Mon 19 Oct 09 @ 8:28 am
You would be wise to backup the My Documents/VirtualDJ folder before reinstall just in case something does go wrong. This is where your settings and database are stored for internal drives. External drives have the database in the root directory of the drive itself, so it will be there when you upgrade. When you do upgrade, it is very important that you have whatever external drives and hardware connected as if you were setup to play a gig.
geposted Mon 19 Oct 09 @ 8:56 am
Go into VDJ folder in documents and copy the database file to your desktop just incase.
Hey Charlie - looks like you and I posted at the same time, lol.
geposted Mon 19 Oct 09 @ 8:58 am
Thanks guys,
This is what I intended to do, just wante to make sure I hadn't missed anything...
Roy
Roy
geposted Mon 19 Oct 09 @ 9:20 am
Nice one, Andrew :)
geposted Mon 19 Oct 09 @ 10:05 am
