Hi,
I have the full version of virtualdj.
Since I updated virtualdj to virtualdj 1.06, the playbutton does not react when I have my hercules console connected with usb on the laptop.
If I disconnect the console than there are no problem when i use the playbutton. If the console is connected than nothing happens even when I use the mouse. Its only the playbutton who has this problem. Other functionalities are without problems.
I re-installed virtualdj and the drivers for the console but nothing works.
The laptop is working on windows xp, directx 9.0c
intel celeron 2,5 GHZ, 256 mb DDR SDRAM
30GB Ultra ATA/100 HDD
Is their someone else who had the same problem?
By the way on my second personal home computer everything works with virtualdj and the console.
Greetings
Hans
Greetings
Hans
geposted Fri 29 Apr 05 @ 2:12 am
"Since I updated virtualdj to virtualdj 1.06"
I think you wanted to say: "Since I updated virtualdj to virtualdj v2.06"
For your problem try to change the usb port or the cable. Sometimes it's the reason
geposted Fri 29 Apr 05 @ 2:10 pm
