ok same progarmme but...
One will not play mpegs/mpg the other will not
i have checked the codecs and both are the same....also while playin a vid if i change the settings on my output for vid it ether freezes or the whole vid drops out....how do i restart the vid with out reloading or restarting VV....and at times have gone in and changed the video on and off in setting...this is a pain to do so......
these thing do bug me as i do gigs with corprate cliants and when this happens i look hmmmm Yeah
geposted Mon 19 Oct 09 @ 7:42 pm
Please re-read this post, because I am having a hard time understanding it.
geposted Tue 20 Oct 09 @ 9:40 am
If the video freezes, often loading another track to the other deck has been reported to unfreeze it
As for the MPEG issue I've seen it mentioned on here before so might be worth a search. You could try Numark support too - if it's widespread then they may have some input.
geposted Tue 20 Oct 09 @ 9:44 am
i have checked the codecs on both and both are the same....
also while playin a video ...
how do i restart the vid with out reloading or restarting Virtual Vinly....
now can you read it?
geposted Tue 20 Oct 09 @ 8:48 pm
