Hi,
Looking for some assistance if possible. At version 6.02 the mapper for the DAC3 changed. I understand it is easier to map now, however I always had an issue wit my tempo sliders being slightly of so I would go into the programming of the unit under the old mapper and fine tune the tempo bar so it would be 0/0 and I did not have to reset the pitch each time, also when I sat in the groove on the tempo slider it was 0/0. Any clue if this can still be accomplished, if so how?
Thanks for the help..
geposted Wed 21 Oct 09 @ 6:53 am
You could try using param_add, e.g: Change the pitch slider mapping to:
param_add 0.1% & pitch_slider
geposted Wed 21 Oct 09 @ 12:29 pm
