Hi all,
anyone knows how to add new songs to a existing playlist?
DJ Omar
DJ Omar
geposted Wed 21 Oct 09 @ 3:17 pm
You've got to load the playlist, add new tracks, then re-save the playlist again.
geposted Wed 21 Oct 09 @ 8:47 pm
thank you DJMGA, i'll try doing that....but the last time i tried doing that, the playlist will disappear from the window.:). I'll give it a shot and thanks for taking the time to respond.
DJ Omar
DJ Omar
geposted Fri 23 Oct 09 @ 5:15 pm
No problem.
If your playlists are disappearing when you search for new tracks, check your Config/Optons Autoload Playlists setting. If set to Always, your playlist will be automatically cleared to be made ready for a new playlist. If that's the case, try changing your Autoload Playlists setting to Disabled. Your existing Playlist should then be preserved...
geposted Fri 23 Oct 09 @ 10:01 pm
