I'm using the Numark DMC2 Controller with VDJ 6. I use the Denon x500 mixer for my audio. However, I'd like to connect the crossfader on my mixer with VDJ. Is there any way to do this, as my digital controller does not allow it (it does not have any inputs or outputs). Can I connect a cable to my computer from them mixer somehow?
Thanks!
Thanks!
geposted Wed 21 Oct 09 @ 5:39 pm
You cant do that with this mixer. Its not a midi mixer.
geposted Wed 21 Oct 09 @ 10:45 pm
You can only do this if you use the X500 in conjunction with a Denon DN-HC4500 controller.
The mixer itself is not MIDI, but it can be linked to the Denon DN-HC4500 which will allow you to video crossfade using the real mixer crossfader (When enabled in the HC4500's MEMO options.) This feature will not work with any other controller.
NOTE: The DMC-2 does have its own automatic video crossfading buttons.
geposted Thu 22 Oct 09 @ 12:27 pm
