Hi guys,
I'm having a hard time getting some "graphics" to be seen on my video screens/Plasmas
There J-peg images, One for instance says "Happy Birthday Jeff & Tara"
They were made by a friend on, i believe, Photoshop
I cannot get VDJ to even see them on the H/D's Any ideas as to getting this to work? I'd like to throw them up when i don't have a
video as a sort of Ambient.
Thanks
Thanks
geposted Thu 22 Oct 09 @ 12:16 am
Use the slideshow plugin?
geposted Thu 22 Oct 09 @ 7:41 am
How do i go about that??
geposted Fri 23 Oct 09 @ 1:06 am
Have a look under the video plugins list in your VDJ window. You'll see an option for slideshow. You can point this to a folder of pictures that will then play a slideshow when activated. Manual activation will override the video output; to use it only when audio files are playing enable slideshow in the config window, video tab - use this plugin for audio only files (or words to that effect).
geposted Fri 23 Oct 09 @ 11:58 am
How do I "point" the slideshow to the folder of images? I can't see an option on it?
EDIT: Found it!
Chris
EDIT: Found it!
Chris
geposted Sun 22 Nov 09 @ 6:15 am
