Hi,
does anyone has experience on using VDJ with a touchscreen ?
I'm thinking of using a second screen along side my Hercules Steel to add some extra buttons.
This works very well, I'm doing the following:
- add keyboard mapper with e.g. CTRL+ALT+1 ... 10 for the extra commands
- I programmed (with mountfocus) extra buttons on my touchscreen
but now I have the following ... for example I programmed 1 key to change a setting and I would like to visualise on the touchscreen that the setting is on or off and when I tap on the "button" again I set it to the opposite setting (when it is OFF set it ON and when it is ON set it OFF...) and let the button light up when this is ON position for two reasons:
1) I don't want to programme 2 buttons for the same function (1 for ON and one for OFF)
2) I can see if the function is ON or OFF
I think that it has something to do with reading the variable but how to implement that in mountfocus ?
anyone ?
anyone ?
geposted Sat 24 Oct 09 @ 10:01 am
Yes, I am using a Allin1 Pro Dj Pc. It is an awesome set up. No need for mouse, keyboard, or controller.Check them out at www.prodjpc.com
Angel S
Angel S
geposted Tue 03 Nov 09 @ 12:00 pm
I too use a Touchscreen setup. You can check out my homemade case and screen at my homepage.
geposted Tue 03 Nov 09 @ 3:48 pm
