^ Bish, thanks a lot. I already played around with Virtual Dj at my friends house often, and I know playing music is what i enjoy doing, and I've been saving to buy some real stuff now.
I'm going to the DJ store today and i'll buy a dj midi controller with a built in soundcard.
I'll test it out if i like it and in 2 weeks I'll make my decision if I should buy the djm 800 or not.
I think the Hercules RMX console has a built in soundcard and also comes with a Virtual Dj version, that you can upgrade to pro for a few dollars?
That would be perfect, if the console is good and stabile.
I hope its not all plastic :p
Ok i'm off to the shop now,
Thanks all of you that helped me!
geposted Mon 26 Oct 09 @ 11:59 am
Well I got the Hercules RMX, took me like 20 minutes or so to set everything up, now i'm mixing and assigning midi functions on Virtual DJ 6.0 Pro trial.
pretty cool, i guess i'll buy the full version after the 20 days are over :p
the only thing missing are 2 knobs per deck for the effects, and some way to select effects..
but the rest is awesome =)
DOes any1 know if you can get all buttons to light, even when they are not used? cuz that would look wicked!
geposted Mon 26 Oct 09 @ 6:31 pm
The RMX is the MIDI controller I'd use if I was on a budget. I have a good old DJ friend (VDJ member DJ Advise) who has been a DJ for over 30 years and even though he's got plenty of $$ like myself he still chose the RMX. So to me, knowing this cat as well as I do, that says a lot about the RMX!
Go get the RMX!! It's worth every penny!
DJ RuDe
Keep Spinnin'!!
DJ RuDe
Keep Spinnin'!!
geposted Tue 27 Oct 09 @ 1:11 am
Welcome to the VDJ family. Just ask and I'm sure there's many here to help u with ur RMX. If you do end up with the djm800 let me know and I'll help in anyway I can!!
geposted Tue 27 Oct 09 @ 4:11 am
No you can't mate. There's only 16 buttons that have the back lighting. There the one's that blink when you first connect the RMX up.
geposted Tue 27 Oct 09 @ 1:02 pm
Unfortunately some of the buttons do not have LED backlights. Those that do will already light up appropriately.
geposted Tue 27 Oct 09 @ 1:04 pm
