Finally upgraded to V6, and have spent the last hour setting up my old Hercules dj console to work as close as pos to previous versions.
The final thing I'm stuck on is that the pitch change knob is too sensitive (!).
Each 'click' of the knob changes pitch by 2.1% when I have +/-33% pitch setup - this is much more than previous versions.
I would expect that there is something I can add to the pitch_relative function in the mapper to change how much each 'click' is, but nothing I've tried does anything useful.
I realise I can change VDJ to use +/-10%, but that's not an ideal solution...
Any ideas?
Any ideas?
geposted Sat 24 Oct 09 @ 3:24 pm
I've already assigned a key to vinyl_mode, and that allows me to use the jog wheels as per V5.
It's the knob I have assigned to pitch rather than the jog wheel. On my hardware, it's actually the volume knob, (I've swapped volume & pitch since I prefer volume sliders).
The sensitivity sliders only seem to affect the jog wheel operation, not the other controls.
geposted Sun 25 Oct 09 @ 5:15 am
Sorry - didn't make myself clear!!
Problem still not solved.
Need a solution that works with the DJConsole volume/pitch knob rather than the jog wheels.
geposted Sun 25 Oct 09 @ 3:15 pm
