how do i get the play list to auto load - so it starts the next song when the other is over???
geposted Sun 25 Oct 09 @ 8:16 am
For simple things like this it would be best to read the instruction manuel found in VDJ folder within documents
geposted Sun 25 Oct 09 @ 10:34 am
That's true, it's just in the start menu, on the same list as virtualdj and the DVD ripper, etc.
But to make your playlist play through, you load it into the "sidelist" (on the right of the main browser window). Hopefully you've found that it pops out when you put your mouse near the right edge of the browser. Then you just click on the magic wand symbol which on the left hand edge of the side list and the music will start to play!
It's definately worth reading the manual though, give's all the useful info!
geposted Sun 25 Oct 09 @ 12:30 pm
