HI, Can anyone reccomend a budget sound card with 3 line outputs so that I can connect my PC (pci) to my mixer. PS Im new to this and not technically minded.
geposted Sun 25 Oct 09 @ 1:07 pm
you can try MAYA USB sound card or GIGAPORT AG.....it's a plug and play....no driver needed.
geposted Sun 25 Oct 09 @ 9:42 pm
I you are looking for professional equipment try the
Native Instruments Audio 8 DJ
Greets, Heiko
Greets, Heiko
geposted Mon 26 Oct 09 @ 9:41 am
Thanks for the advice, I will check these out and let you know of my outcome. Cheers Tony
geposted Mon 26 Oct 09 @ 2:35 pm
Does NI 8 run with snow leopard?
geposted Mon 26 Oct 09 @ 5:19 pm
