hey im only 14 so if these questions seem dumb to you dont be an a** uhm i have staton turntables and i just bought tora conectiv vinly and cd pack uhm what i planed on buying was i think a sound card so what i do on my turntables would happen on the DJ program ..now like i said im 14 so i have really know idea what im doing now were i bought this they had another thing that what i do on my turntables shows up on the program but that was more money and i wasnt really thinking can some one tell me what the tora conectiv vinyl and cd pack does and if i should get that.. thanks lol
geposted Sun 25 Oct 09 @ 9:31 pm
What I can tell you:
1.- I recommend VirtualDJ, so in your case I recommend you better go for an Hercules DJConsole RMX, you can use it at first place with console and VirtualDJ LE. Also This console let you use timecodes. This option cost about 350 usd or 500 usd with timecodes use.
2.- Or what you ask in VirtualDJ, you need VirtualDJ Pro and 2 timecode (I recommend VirtuaDJ or Serato Timecodes only) In this scenario you need a comaptible soundcard for timecodes, so you can use NI Audio 4 or Maya 44 USB. This option cost about $550 usd, maybe 450 if you get the maya instead of NI Audio 4. You need 2 CD-Players or Turntables and a mixer to complete this option.
Good Luck!
geposted Sun 25 Oct 09 @ 10:47 pm
