cdj400 can work with but the hercules rmx as mixer midi?
thank everyone
geposted Mon 26 Oct 09 @ 7:07 am
Yes, I believe it will. You will only use the RMX as a mixer connected to the CDJ-400s via RCA cables. The CDJ-400s will connect to your computer via USB.
Make sure you have the proper through-put (input/output) buttons engaged on the RMX so you can use the outside sources (CDJ-400s).
DJ RuDe
Keep Spinnin'!!
DJ RuDe
Keep Spinnin'!!
geposted Tue 27 Oct 09 @ 1:16 am
Were you able to determine if the CDJ-400 worked with the RMX?
geposted Fri 04 Dec 09 @ 5:55 pm
They are separate controllers and can be used at the same time.
geposted Sat 05 Dec 09 @ 5:43 pm
Thank you for clearing that up.
geposted Sun 06 Dec 09 @ 7:47 am
hey guys,
i have cdj-400 and a hercules rmx. I know i can use the hercules rmx as a mixer but how do you connect everything with eachother.
i mean where does wich wire go so that everything works good.
thx....DR.
thx....DR.
geposted Fri 05 Nov 10 @ 7:15 pm
Cant you use timecodes in the cdj400 and just hook the two cdj400's up to the rmx with rca cables????? then the rmx to your computer with the usb
geposted Mon 08 Nov 10 @ 8:06 pm
