Does anyone have the drivers for the Numark VV soundcard, for the 64 bit version of windows vista....please help..thanks jon
geposted Mon 26 Oct 09 @ 10:13 am
No 64 bit drivers out for VV yet, as far as I know. Let's see if we can get an estimate from a rep... ;-)
geposted Mon 26 Oct 09 @ 10:30 am
Hi, the existing drivers will work on most 64 bit computers.
Make sure you install the latest VV before you connect the box.
geposted Mon 26 Oct 09 @ 10:36 am
I do have the latest software....it doesn't recognize my VV soundcard and windows can't find drivers...I'm using vista home 64bit
geposted Mon 26 Oct 09 @ 11:38 am
Send me a PM with your email and I have something you can try.
geposted Tue 27 Oct 09 @ 4:15 am
I have the same problem, control box does not work with a 64bit OS. If there is a way to get it to work I would really like to know as well, thanks.
geposted Fri 30 Oct 09 @ 6:57 am
i have the same problem. just purchased a new 64bit laptop only to find out that VV only works with 32bit. I've contacted numark reps about 4-5months ago and they said they dont have any drivers available for 64bit yet.....booooooo!!!!!! but im still managing on an older laptop (32bit of course). COME ON NUMARK, lets keep up!!!
geposted Wed 04 Nov 09 @ 3:49 am
oh btw....ive been researching on alternatives. try using Audio 4 0r 8 sound card from Native Instruments($300-500). it can be used for 64bits. Just hook up the same way as you would with the VV soundcard. hope that helps.
geposted Wed 04 Nov 09 @ 3:53 am
