In 6.0.2 I now see 2 Numark ASIO devices in Sound Setup. One is Numark Audio Device and the other is NS7 related. I have the Numark DJIO, not the NS7. Do they share the same driver now? Should I still be using the one that says generically Numark Audio Device or the NS7?
geposted Mon 26 Oct 09 @ 1:45 pm
Does the "Numark USB" standard DJio option work?
It may be Cue/VDJ has set this up automatically.
geposted Tue 27 Oct 09 @ 4:15 am
The Numark USB is the only one I have used with my DJIO, yes. It works just fine. I just have no idea where the NS7 driver came from? I have never had one connected to my laptop. It must have come with the Numark Cue 6.0.2 installation... or perhaps the Virtual DJ install too?
I have both installed as I use Cue 6.0.2 with my DJIO/DMC2 setup, and then use the Virtual DJ 6.0.2 setup with my Audio4DJ/Stealth Control setup. It allows me to not have to flip flop my sound, performance, and latency settings between the two setups. :)
It is not bothering anything... i just have no idea how it got there. lol
geposted Tue 27 Oct 09 @ 10:09 pm
