i have a mixer i just bought behringer djx 750 to work with denon 3700 trying not to buy another one. i look at all the mixers recommended by vdj very expensive. can someone suggest a mixer that is not so expensive in the range of 350.00 that would work with the denon 3700
geposted Mon 26 Oct 09 @ 7:11 pm
whats wrong with 750?? I use mine no prob?
geposted Mon 26 Oct 09 @ 8:23 pm
If you are not looking to control the software from the mixer (E.g: Video crossfader), then any standard DJ mixer can be used.
geposted Tue 27 Oct 09 @ 1:05 pm
agreed..but if you are looking to control the software for that price I would go witrh the RMX best for the price!! I use both the DJX750 and RMX @ my gigs no prob...
geposted Tue 27 Oct 09 @ 4:48 pm
