I need answer , can i use Virtual dj with Audio2DJ soundcard (from Native Instruments), here is technical info about card, i need fast answer because i try to buy these card
http://www.sonarscope.hr/ducan/index.php?main_page=product_info&cPath=2&products_id=292
and
http://www.skratchworx.com/news3/comments.php?id=1273
and
geposted Tue 27 Oct 09 @ 5:41 am
Since this card is designed to work with DJ applications, there is no reason it wouldn't work with VDJ, as do the Audio DJ 8 and Audio DJ 4.
geposted Tue 27 Oct 09 @ 6:24 am
ok, thanks i will buy card ;)
geposted Tue 27 Oct 09 @ 9:11 am
Hey guys,
I baught this AUDIO2Dj and I cant setup it correctly with VDJ
Can someone help me plz
geposted Tue 22 Dec 09 @ 7:07 pm
What do you want to do, and what does it do at the moment?
Don't forget there is a manual in the virtual dj folder on your computer
geposted Wed 23 Dec 09 @ 4:42 am
When i use the audio2dj with vdj, the sound is not as good quality. Is like listening to radio wit no network. I tried with my desktop and it works fine. I guess my laptop is kinda old, well is 1Gb ram.
geposted Wed 23 Dec 09 @ 7:43 pm
