Can someone tell me how to add a playlist to the right side where my virtual folders are?? I click on the "playlist" and nothing happens.. I tried to right click on it, and still nothing happens.. is there a something that I need to his to add a playlist that I am missing???
geposted Tue 27 Oct 09 @ 3:06 pm
I thought virtual foldes were on the left with all the other folders.
geposted Tue 27 Oct 09 @ 3:42 pm
Yep, that's the left side! If nothing happens when you click on Playlist (on the left-hand side), it means you've no playlist saved. To create them, load tracks into your Sidelist (right-hand side), click on your Playlist Management button (bottom button, top-left of your sidelist window) and select Save. You'll get a pop-up window asking for a Playlist name.
Once you save your playlists, they'll appear once you click on Playlist.
geposted Tue 27 Oct 09 @ 7:57 pm
