I want to buy dj software for my denon dn-s3700s (2 of them) and I want to know if I should buy Virtual DJ or Numark Cue. I know the Cue is the same as VDJ, but I've seen read on other forums that Cue is more stable. Will both work with my denons? Which one is better?
Thanks DJ Pals :)
Thanks DJ Pals :)
geposted Wed 28 Oct 09 @ 7:12 am
How can cue be more stable when virtual Dj is the original software? Anyway, it will work with either. I say go with the Virtual DJ because its updated sooner.
geposted Wed 28 Oct 09 @ 2:36 pm
thank you. I had downloaded VDJ trial to test my setup and it worked but when i mixed two songs together one was going slightly faster even though the pitch was the same. how can i stop this?
Regard DJ Pals
Regard DJ Pals
geposted Thu 29 Oct 09 @ 2:49 pm
The Sync feature if you are using this is good for most tracks but on some you need to manually tweak the speed with the pitch controls.
This video is helpful to explain how this works.
geposted Wed 11 Nov 09 @ 4:11 am
