Anyone know of a skin that will fit this resolution nicely? I like the default skin, but I'd like to go full screen, without stretching.
geposted Wed 28 Oct 09 @ 11:11 am
Try this skin
https://virtualdj.com/addons/8558/Over_Flow_Odd.html
geposted Mon 02 Nov 09 @ 8:30 pm
It doesnt make any sense to try to pick a skin that fits your native resolution.. Why cant the skin be automatic no matter what resolution your screen is set to. The skin you may preffer doesnt fill up completely and the skin you change it to doesnt look all that..
geposted Mon 02 Nov 09 @ 8:47 pm
I raised that subject in the "skin" forum.
I did not get a good response.
https://virtualdj.com/forums/117084/Virtual_DJ_Skins/Skin_sizes.html?search=snap%20to&page=1
geposted Mon 02 Nov 09 @ 8:49 pm
I bet if there was something wrong with the get food feature.. It would get fix imediatley..
geposted Mon 02 Nov 09 @ 8:56 pm
Funny how things work sometimes.
geposted Mon 02 Nov 09 @ 9:01 pm
You MUST use the native resolution skin, otherwise, because of this bad made resize system included in the new 6.x version of VDJ, you will see your CPU over used all the time !!!.
I don't know what are the developpers doing since many month that this "bug" as beeen mentioned. We need a new version with a really better resize skin system because acually it's not running and kill your machine performances
geposted Tue 03 Nov 09 @ 4:13 am
1280x800 is a pretty standard wide screen size.
Most monitors have this setting in their control panels.
I remember not to long ago when all we had was 800x600, can you imagine living with that today???
Stretching skins is not advisable and development is pretty busy fixing other priorities at this time.
As they say, you can have it good, you can have it fast, but you can't have it good and fast.
geposted Tue 03 Nov 09 @ 6:13 am
