[Can I use denon 4500HC in Virtualvinyl. I can´t find any remote control tab
geposted Fri 30 Oct 09 @ 9:57 am
Yes - It has been supported for some time now.
If you are using an older version of the software, you will need to upgrade to the latest v6: https://virtualdj.com/download/updates.html
In v6 there is no Remote Control tab. Supported controllers will be detected and used automatically at start-up. Simply ensure that the HC4500 is connected to your computer and switched on before starting the software.
Also, please ensure that you have the latest Denon firmware and drivers installed: http://www.denondj.com/DN-HC4500-P81.aspx
geposted Fri 30 Oct 09 @ 1:42 pm
jpboggis, will the new firmware update effect using version 5.21 with HC4500
geposted Fri 30 Oct 09 @ 1:55 pm
Thanks for that, I install Denon 4500HC and auto.m the controller came up.
Thanks
Guys
Warm regards from Canarian Islands today +35 C
Thanks
Guys
geposted Sat 31 Oct 09 @ 8:11 am
