Hi,
I have finally managed to set up timecode properly. But there's still a problem i don't know how to fix.
When i'm prelistening the track from the other deck (which isn't being played through the speakers) with my headphones, everything is fine, but if i pause the track (but keep listening through headphones), i constantly hear a crackling noise...
it's annoying if you are about to wait to start the track to beatmatch it with the other track...
i hope someone can help me out :)
thx,
cya
thx,
cya
geposted Sat 31 Oct 09 @ 2:06 pm
It's pretty strange.
Are you using beatmatch during your mix with timecode?
geposted Sat 31 Oct 09 @ 2:44 pm
just a guess, but it sounds like a needle problem.
I like to clean the connections between the headshell and the tone arm (use an eraser)
geposted Sat 31 Oct 09 @ 5:10 pm
Dont know how but the problem is solved :D but another problem occured :(
if i play a track and set a cue point (with the cd player) but then go back to that cue point, the cue point isn't at the right point anymore, it sounds like it has moved 1 sec backwards :/
i'm using numark axis 9 cd players & maya 44 usb
is it maybe because i'm using the pro grades tcd cd's? (low grade doesn't work..)
cya
cya
geposted Sat 31 Oct 09 @ 7:48 pm
