I know the beatlock does not work, but are the waves still displayed and can the dashes be used as a visual aid to help with you mixing?
I play in my apartment and I can not really blast my music, so the visual aid comes in handy.
thank you.
thank you.
geposted Sun 01 May 05 @ 10:12 pm
It's easy ...don't worry about that ...if you go for TCV you will never use beatlock or sync
geposted Mon 02 May 05 @ 3:59 pm
is it possible to sync with TCV? or do you have to use the pitch on the turntable, and that does not reflect the BMP on the screen does it? i would like TCv and just have them sync'd for easy of mixing.
geposted Tue 03 May 05 @ 3:41 pm
Hello there!!
YES you can sync with the TCV!!! without using the pitch from the turntables!!!
I never use the pitch (always stays in the midle), from the turntables!!!
Just push the spacebar AND YOU GOT YOUR BEATMACH!!!
Best regards.!!!
Best regards.!!!
geposted Tue 03 May 05 @ 10:19 pm
the waves are still displayed :)
geposted Thu 05 May 05 @ 10:17 pm
as mr.walkers said:
"the waves are still displayed :)"
but they still move in time with the record, and the CBG also moves with it, after modifying the pitch on the turntable, it takes a few milliseconds, and the CBG and wafeform display updates to reflect the new speed.
Just thought I'd elaborate on mr.walkers comment ;)
geposted Mon 09 May 05 @ 12:53 pm
