guys i have just updated to v6.2 and doin a pre test before next weeks gig.
every things fine but my scroll dials have lost the sensitive setting when cueing in,
the page button as many of your are aware flips from scratch to fine pitch/scroll
had a look at the settings but not sure were i am going wrong, its stuck on scratch?
help please?
help please?
geposted Sun 01 Nov 09 @ 11:17 am
Have you done any modifications with the Omni mapper?
How about the Keyboard shortcuts, did you add/modify anything that will relate to your problem?
Quick remedy is to revert the highlighted mapper to factory settings then see if it works. Revert button is located just below the mapper section page, left lower corner.
For the Jog Cue sensitivity, try playing with the sliders on the Option page and set it to your own taste.
Hope that helps
Hope that helps
geposted Tue 03 Nov 09 @ 7:43 am
