Does anybody know if the Maya 44 works with windows 7 64-bit? I just got my new laptop and wount let me use the virtual vinyl box and i dont really want to downgrade to a 32-bit. Or is there a sound card that its supported by the 64-bit OS i can use??
geposted Mon 02 Nov 09 @ 4:02 am
You can find the latest driver for MAYA 44 USB from ESI
http://download.esi-audio.com/?w=esi&p=40&g=2&l=en
It's works for me on Win 7 64-bit and time code vinyls
geposted Mon 02 Nov 09 @ 11:27 am
Thanks!! Good to know before i buy.
geposted Mon 02 Nov 09 @ 3:53 pm
thanks alianz i was having a lot of trouble i downloaded a lit of drivers but they didnt work
geposted Fri 02 Apr 10 @ 6:33 pm
i whent to the esi-audio.com but i dont know wt i download it said it was the drivers but i dont know why it didnt wor but the one u put it wor thanks
geposted Fri 02 Apr 10 @ 10:11 pm
Hey ALienZ, Did you have any trouble installing the driver on win 7 64 bit ? Everytime I do the install it says it was successful but when I go the the windows device manager it says 'Device cannot start (Code 10)'
Driving me crazy, any help would be great.
Cheers
Cheers
geposted Wed 26 Jan 11 @ 8:47 pm
Finally got it installed and working. Unplugged all other USB and tried a different port for the Maya.
geposted Thu 27 Jan 11 @ 4:37 am
hello im using the maya 44 works fine into i wona go back to using my cds .. it used to work fine about todays ago you could hear your input when you turned them on now when i turn my input on they come back out on chanel 3/4 wich is ov no good any help plz thanks guys
geposted Tue 08 Feb 11 @ 7:32 pm
