Ok I know I see a few posts on this but I can't really find the answers to my questions
when I searched.
I am looking to buy a new controller to replace the ICDX which have served there time well.
DENON DN-HS5500CD Seems to available at an alarming Discounted rate
I have Tested the DNS-3700 with Virtual DJ and it works GREAT!
A Few Things I did not get to test.
1) Will the 5500 work just as good as the 3700
2) Can I use two of them??
3) How good is the soundCard ?
4) The 5500 has a 4 Channel SoundCard. which is more appealing because I can use the second Decks output for samples
Did anyone try this???
5) I can't find the HS5500 anywhere to do a hands on Test. Should I just settle for the 3700?
Thanks,
DJ SMG!
when I searched.
Thanks,
DJ SMG!
geposted Thu 05 Nov 09 @ 1:10 pm
I personally like the 3700 better, but I had a 5500 when they first cam out and I loved it. I am sure they work even better since 5.2.1 that I was using at that time.
geposted Thu 05 Nov 09 @ 1:14 pm
I think I am just going to have to use the 3700 because
no one seems to know about the 5500 and I can't find them in the stores to really find out myself
so I will just have to get what I "KNOW" Works well
geposted Thu 05 Nov 09 @ 5:03 pm
