Hello VDJ forum users!
I have the Hercules RMX and I've been fully satisfied with it. Until today.
Earlier I tried to plug the controller to my computer and with the result of a crazy blinking midi-controller. It's not the usual continuously blinking like it needs to be firmware updated. It begins after 2 or 3 minutes after I plug it in. I tried downloading "Midi Monitor" to check if the RMX was broke - it doesn't work in VDJ - and it works well in Midi Monitor for about 2 or 3 minutes, but then it starts blinking random and like a maniac on speed.
- I have tried to update the firmware a million times (31).
- I have the latest version of the Hercules drivers.
- I have the latest version of VirtualDJ
What can I do? plz help!!
Sincerly
FENGERSWAY
Sincerly
FENGERSWAY
geposted Thu 05 Nov 09 @ 6:00 pm
Disable general powersaving in the windows control center.
Do you have disabled 'powersaving' on every root hub ???
Change the USB cable to a 'better' one.
Hope this will help,
Heiko
Heiko
geposted Fri 06 Nov 09 @ 10:53 am
Hello Jakovski.
Thanks very much for the reply.
But it still doesn't work :(.
Tried to what you said, but it still fucks me up. Do you think it is broken?
Sincerly
FENGER SWAY
Sincerly
FENGER SWAY
geposted Fri 06 Nov 09 @ 12:09 pm
How about the USB port of the console? Does it seems to be loose in someway, which could indicate that the inside soldering could be broken, which could induce a short, making the console behave that way.
Also, do you remember or noticed if the console might have been shocked (static) ? If you shake it, do you hear anything moving inside ?
geposted Fri 06 Nov 09 @ 1:51 pm
