i, im a starter ang bought myself an X Session Pro works great but the only things is i don't know how to plug my earphones into it. can you help me?? do the Cheap USB sound card works? or what is the Y Adapter?? HELP Im so confused.
geposted Sat 07 Nov 09 @ 1:46 pm
Hi mate
Are you using a laptop or a desktop PC?
Which version of VDJ are you running?
Daz
Daz
geposted Sat 07 Nov 09 @ 2:03 pm
usb will work fine
geposted Sat 07 Nov 09 @ 11:38 pm
Laptop..
Virtual DJ 6
Virtual DJ 6
geposted Sun 08 Nov 09 @ 2:29 am
Hi Mate
Yes you can pick up a usb card to provide your master output and configure VDJ to use the laptops built in card for headphones or vice versa depending on what you find works best.
If you find VDJ works well for you, you might also want to look at some of the great little combination units out there. They will give you a mixer/controller/ sound card /all in one unit and many of them come with an LE copy of VDJ to get you started and registered.
best of luck
Daz
best of luck
Daz
geposted Sun 08 Nov 09 @ 2:59 am
