Hi
Im experiencing problems with the crossfader.
Im using a Indigox card on the laptop, and one output is for the headphone, and one output is for the external mixer (master).
When im previewing a track through the headphones, I can hear the preview track fine, but the problem is when I move the fader over to the master, I am not hearing the two tracks starting to mix through the headphones, I only always hear the track Im previewing.
How do I get it so that as I move the fader across, it also mixes in the track on the other deck which is being played to the dance floor?
I didnt used to have this problem, and I dont know why its started recently???
Thanks
Thanks
geposted Sun 08 Nov 09 @ 8:39 pm
Silly mistake - Just incase anyone else ever needs, here is what i got from one of the other guys. Thanks!
On the default v6 skin, check the position of the CUE knob in the mixer section. This determines how much of the master output you will hear in your hedphones. When set to minimum, you will only hear the audio of the deck selected for PFL only (The one you are cueing up.)
geposted Mon 09 Nov 09 @ 6:55 am
