Forum: German Forum
Topic: 6.03
Moin an alle,
Hab da mal ne Frage...sorry wenn sie vielleicht schon mal gestellt wurde...
Wann wird die 6.03 vermutlich bereitgestellt??
Danke schon mal!!!
geposted Tue 10 Nov 09 @ 7:44 am
Schätzungsweise in ca 3 Monaten :-D
Ne, wenn alles klappt dann heute.
Sobald sie fertig ist ;-)
Da sind schon noch einige Tests zu machen.... Habt einfach noch etwas Geduld.
:-))) Scherzkeks
Vielen Dank...dann weiß man ja wenigstens bescheid!!!
Fertig. Die neue Version ist ab sofort im Download Center.
hier noch die Änderungen:
- fixed search crash
- [mac] fixed random crashes
- fixed crash on v5 skins with v6 actions
- fixed crash on reload itunes subfolder
- fixed "goto -1" to stay in sync
- fixed set_cue sometimes not saved
- fixed goto_cue and hotcue when looped to keep the loop
- open in explorer selects the file
- forced mix starts from the selected transition type's entry point
- soundconfig changes saved when switching to another tab or closing the options dialog
- fixed headphone_mix in automix
- fixed no long sort on filedate
- fixed cracks with equalizer and safemode
- fixed videos with multiple AC3 tracks
- fixed smart_scratch in reverse mode
- fixed djc_button_popup
- fixed sort in playlist reload next track if changed
- fixed click on coverflow keeps selected song in view
- fixed fade to black kept if disabled
- fixed dump can stay stucked
- fixed volume keys on keyboard for shortcuts
- fixed unicode in karaoke zip
- fixed unicode in playlist/history
- fixed unicode in broadcast infos
- fix unicode and accents in search box
- fixed case insensitive search for unicode chars
- space in search matches '-' or '_'
- [mac] fixed action learn on mapper page
- [mac] fixed drive column
- fixed CDJ400, MEP7000
- fixed stealth and omni mappers/devices
- fixed ns7 platter speed not correct
- fixed ns7 sound jumps when beattap or scrolling in songs
- fixed hercules steel definitions (right stop button)
- fixed Hercules Trim audio
- fixed Hercules RMX audio in loopback mode
- added CDJ2000, CDJ900
- search in greek and russian can use transliteration
- don't add to searchdb files that are not physically present (from itunes, history, playlists, etc)
- added timecode engine v4
- better layout in the mapper dialog
- optimized memory managment
- new action: set_gain, preview, loop_button
- new timecode debug option: smooth pitch
- new config/option: vinyl mode
- new folder context menu: create subfolder
- can drag and drop files from within virutaldj, by pressing CTRL when dropping over a folder
- soundengine quality improved in safemode
und vieles mehr. Diese sind aber nur kleinigkeiten und muss man nicht unbedingt erwähnen :-D
https://virtualdj.com/wiki/VirtualDJv6.0.3.html
