sclavel wrote :
Hello,
A new version is now available, version 6.0.3.
(see the changelog)
As usual this update is available for FREE for all VirtualDJ Pro users.
Go to your Download Center to download it.
This version is mainly a bug fix, and corrects many small issues that were left from the previous release.
So even if you don't have any problems with your current version, we recommend downloading and installing this new version anyway.
(see the changelog)
geposted Tue 10 Nov 09 @ 8:21 am
I had a quick test, and seems to be working fine. As always, I used AppCleaner to remove the old version before installing 6.0.3.
Subjectively I'd say scratching and keylock sounds better. The former was never and issue since I'm not into scratching - even less so with jogwheels. The latter on the other hand has been a much expected feature.
geposted Tue 10 Nov 09 @ 12:06 pm
Please note this version is for 10.5 and better only.
geposted Tue 10 Nov 09 @ 1:43 pm
i cant believe my eyes. I can finally use my hercules steel right stop button...... PLUS all the lagging has gone.
So far so good, only had a slight glitch for some reason i could not open the manual bpm edit, i shut down and reopened and it seemed to do the trick. So far the only crash i am getting is when i close the program.
I dont have the time to check more until end of the week but i have done a lot of slagging of to you guys (and i had a valid reason) but if all is ok i will be glad to say thank you and well done.
I may finally be able to use vdj mac for the first time live at a gig, fingers crossed.
geposted Tue 10 Nov 09 @ 3:19 pm
Glad to hear Tim
geposted Tue 10 Nov 09 @ 3:54 pm
I have bad news
Timecode don´t work and make crashes:
Process: virtualdj [340]
Path: /Applications/virtualdj.app/Contents/MacOS/virtualdj
Identifier: com.atomixproductions.virtualdjpro
Version: ??? (6.0.3)
Code Type: X86 (Native)
Parent Process: launchd [75]
Interval Since Last Report: 468 sec
Crashes Since Last Report: 4
Per-App Interval Since Last Report: 244 sec
Per-App Crashes Since Last Report: 4
Date/Time: 2009-11-10 21:27:40.307 +0100
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: CB43CF65-BD7F-429A-BC21-6202695E34CC
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000014aa2000
Crashed Thread: 13
Thread 0:
0 libSystem.B.dylib 0x909962ce semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x9099dda5 pthread_mutex_lock + 569
2 com.apple.audio.CoreAudio 0x91868413 CAMutex::Lock() + 63
3 com.apple.audio.CoreAudio 0x9188fe39 IOA_Device::StartCommandExecution(void**) + 41
4 com.apple.audio.CoreAudio 0x9188fcff HP_Device::ExecuteCommand(HP_Command*) + 63
5 com.apple.audio.CoreAudio 0x91897072 HP_HardwarePlugIn_DeviceStop(AudioHardwarePlugInInterface**, unsigned long, long (*)(unsigned long, AudioTimeStamp const*, AudioBufferList const*, AudioTimeStamp const*, AudioBufferList*, AudioTimeStamp const*, void*)) + 126
6 com.apple.audio.CoreAudio 0x91896fbc HALPlugIn::DeviceStopIOProc(HALObject const&, long (*)(unsigned long, AudioTimeStamp const*, AudioBufferList const*, AudioTimeStamp const*, AudioBufferList*, AudioTimeStamp const*, void*)) + 52
7 com.apple.audio.CoreAudio 0x91896f86 HALDevice::StopIOProc(long (*)(unsigned long, AudioTimeStamp const*, AudioBufferList const*, AudioTimeStamp const*, AudioBufferList*, AudioTimeStamp const*, void*)) + 38
8 com.apple.audio.CoreAudio 0x91896f1b AudioDeviceStop + 161
9 ...pple.audio.units.Components 0x70011559 AUGenericOutputEntry + 7177
10 ...pple.audio.units.Components 0x700126d6 AUGenericOutputEntry + 11654
11 ...pple.audio.units.Components 0x70014afe AUHALEntry + 46
12 ...ple.CoreServices.CarbonCore 0x93a9a9c9 CallComponentDispatch + 29
13 ...apple.audio.units.AudioUnit 0x942ba9d5 AudioOutputUnitStop + 37
14 ...mixproductions.virtualdjpro 0x0003ebe2 non-virtual thunk to CListView::Thread() + 26570
15 ...mixproductions.virtualdjpro 0x0003ec88 non-virtual thunk to CListView::Thread() + 26736
16 ...mixproductions.virtualdjpro 0x0003a6d8 non-virtual thunk to CListView::Thread() + 8896
17 ...mixproductions.virtualdjpro 0x0003b1dc non-virtual thunk to CListView::Thread() + 11716
18 ...mixproductions.virtualdjpro 0x000d3730 non-virtual thunk to COutputMacDJC::Thread() + 34926
19 ...mixproductions.virtualdjpro 0x000d663a non-virtual thunk to COutputMacDJC::Thread() + 46968
20 ...mixproductions.virtualdjpro 0x000d6c1c non-virtual thunk to COutputMacDJC::Thread() + 48474
21 ...mixproductions.virtualdjpro 0x000d4888 non-virtual thunk to COutputMacDJC::Thread() + 39366
22 com.apple.AppKit 0x9512fe8f -[NSApplication sendAction:to:from:] + 112
23 com.apple.AppKit 0x9512fdcc -[NSControl sendAction:to:] + 108
24 com.apple.AppKit 0x9512fc52 -[NSCell _sendActionFrom:] + 169
25 com.apple.AppKit 0x9512f2ab -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1827
26 com.apple.AppKit 0x9512eafe -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 541
27 com.apple.AppKit 0x9512e3b8 -[NSControl mouseDown:] + 888
28 com.apple.AppKit 0x9512caf7 -[NSWindow sendEvent:] + 5381
29 com.apple.AppKit 0x956a4b33 carbonAppWindowMouseHandler + 269
30 com.apple.AppKit 0x9538f5b1 carbonAppWindowHandler + 120
31 com.apple.HIToolbox 0x94ab913d DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
32 com.apple.HIToolbox 0x94ab857b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
33 com.apple.HIToolbox 0x94ad4ecc SendEventToEventTarget + 52
34 com.apple.HIToolbox 0x94ae70a8 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1208
35 com.apple.HIToolbox 0x94ab94f6 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
36 com.apple.HIToolbox 0x94ab857b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
37 com.apple.HIToolbox 0x94ad4ecc SendEventToEventTarget + 52
38 com.apple.HIToolbox 0x94b41a6c ToolboxEventDispatcher + 86
39 com.apple.HIToolbox 0x94b3e2c2 RunApplicationEventLoop + 222
40 ...mixproductions.virtualdjpro 0x00084f6a readatomhdr(void*, TQTAtom*) + 52204
41 ...mixproductions.virtualdjpro 0x000026b6 0x1000 + 5814
Report Version: 6
Crashed Thread: 13
Thread 0:
geposted Tue 10 Nov 09 @ 4:04 pm
Broadcast and record with line in/mic still don't appear to be working with snow leopard. Disappointing.
geposted Tue 10 Nov 09 @ 4:07 pm
It seems almost malicious, but VT 6.0.3 Mac when open If one goes and opens config option an click on anything to reconfigure the sound cards and press apply only one deck plays with the Denon DN-S1200 the other deck goes back to the default computer soundcard. Soundcard reconfig does not get saved. As far as i am concerned this is a beta version still. That would be a major blow for me to use this at a live event and loosing one channel in the middle of a gig.
Anyways, an update Is an update thank you Virtual DJ staff. An A for the effort!
geposted Tue 10 Nov 09 @ 5:12 pm
Just installed 6.0.3 version of VirtualVinyl and guess what? The timecode is still f*****d!
First off here are my specs:
2.4 gHz MacBook with 4 gigs of RAM
Snow Leopard 10.6.2
VirtualVinyl soundcard with Serato CV02 timecode vinyl
Just like in 6.0.2, timecodes don't work properly in relative mode in 6.0.3. When I adjust the pitch on the turntable the keylock doesn't work and when I change the pitch on my turntable the track speeds up but there is no change in VV's pitch display (stays at 0% and pitch slider on skin doesn't move). Also, I have to click on the output in the timecode window of the config menu like 50 times before it does what it's supposed to, and then when I close the config window the sound disappears. Funny thing is that everything works as it should in absolute and smart relative mode.
I'm so pissed right now. Seriously... wtf???
This issue was mentioned by me and a couple of other people during the previous update and I see absolutely nothing was done about it. So once again I'll have to revert back to 5.0.2.
Did you guys even test this version on a Mac?
Snow Leopard 10.6.2
geposted Tue 10 Nov 09 @ 7:45 pm
Hi Aural
Wheres Appcleaner? what could happen if i do not remove the old files and just overwrite them?
geposted Tue 10 Nov 09 @ 7:58 pm
I should also mention that after a bit the VV souncard went nuts and caused the tracks to play erratically when the vinyl stopped. I've reverted back to 5.0.2 (thank god for the back-up program SuperDuper) and everything is back to normal.
geposted Tue 10 Nov 09 @ 8:52 pm
AppCleaner is third-party utility that removes application and all the files associated with it. It's free and you can download it from here.
It's just a precaution, but the point is to prevent a situation where your application is version X but the assosiated files are for version Y, which could theretically mean they are not compatible with each other.
This principle applies to all Mac software, not just VDJ. Sometimes applications install some additional config files, libraries etc. which won't get deleted when you just drag the application to trash can. That's why using an utility like AppCleaner is recommended.
geposted Wed 11 Nov 09 @ 3:16 am
New version works good.When working with videos (.vob) memory using is decreased. Everything works perfectly.
Thank you very much for this!
I am using:
MacBookPro 13"
OS X 10.6.1
2,26 GHz Intel Core 2 Duo
Mem. 2 GB DDR3
NVIDIA GeForce 9400M
Hercules DjConsole MK2
I am using:
MacBookPro 13"
OS X 10.6.1
Mem. 2 GB DDR3
geposted Wed 11 Nov 09 @ 4:48 am
Hola, me gustaria si me pueden ayudar para saber donde puedo conseguir el Virtual 6 de prueba para MAC ya que tengo un Macbook pro 13", 2,56 Ghz con 4M y lo quiero hacer endar con un Numark Omnicontrol. Ahora lo tengo sonando con un HP en versión Windows y me reconoce todas las funciones del Omni Control.
gracias
DjLex
gracias
DjLex
geposted Wed 11 Nov 09 @ 8:26 am
gracias
DjLex
gracias
DjLex
perrin este es el foro de mac, postea en el foro en español
geposted Wed 11 Nov 09 @ 10:24 am
Este foro para MAC es en inglés
No hay version de prueba para MAc todavía. En el foro en Español hay un apartado para Mac en Español.
Respete las normas del foro.
geposted Wed 11 Nov 09 @ 12:38 pm
Having trouble with timecode also. I configured the timecode settings and hit apply and then crashes. I also use app cleaner to delete previous virtual dj pro and still has the same problem.
geposted Wed 11 Nov 09 @ 12:51 pm
Installed up date last night. Same problems with video freezes. Went back to 5.21 -- so I'm still in business. BTW, did the same thing with windows in boot camp... same result.
geposted Wed 11 Nov 09 @ 8:24 pm
I cannot make my ESI U46DJ work with either with the 5.2 version nor the 6.03 version. When I go to the sound configure menu I choose the u46dj sound card , external mixer and double timecodes and 4 channel card. When I push the "apply" botton the system crashes after it stucks for 2 minutes.
I have to mention thea I have installed the latest mac drivers for my sound card and the systems sees it allright untill the time I am trying to use it with virtual dj.
Is there any solution to this problem? As a second solution I have ordered the hercules rmx which works fine with the 6.03 version as I read the above posts...But I prefer using other controllers like numark which doesn't have a soundcard or timecodes that i found them easier...
Thanks a lot
Thanks a lot
geposted Fri 13 Nov 09 @ 7:15 am
I checked ESI's website and in the download section there is only "Control panel" for U46DJ and U46SE, but not any actual driver.
I haven't tested the U46DJ with Mac, but I once tested my friends U46SE which is basicly the same device without phono-preamps. That device was not compatible with Mac OS X as a multi-channel device. I was able to use it only as single-channel standard USB-audio device.
Product manual doesn't even mention any kind of CoreAudio/Mac OS X support.
geposted Sat 14 Nov 09 @ 4:17 am
