Does 6.0.3 support Itunes Librarys? If I select Itunes Library it does not show up at all (blank). I'd like to know if this is a supported feature or not. Thanks@
geposted Tue 10 Nov 09 @ 8:50 am
It is supported.
You need to choose "Show iTunes" in the browser pane in the config menu.
geposted Tue 10 Nov 09 @ 9:43 am
When I chose Show Itunes the left pane is completely blank. It doesnt show any text at all. This happens in both 5x and 6x on my system.
With the Itunes library checkbox checked - my screen looks like this:
I'm guessing i have to completely remove the program and reinstall. I tried dragging the app to the trash and reinstalling but this did not fix the probelm.
My itunes library is in the Default location
geposted Tue 10 Nov 09 @ 9:52 am
Thoughts?
geposted Tue 10 Nov 09 @ 12:13 pm
head over to fill out a support ticket there are many reasons why this happens.
geposted Tue 10 Nov 09 @ 12:15 pm
Filled out support request yesterday with no answer. I figured it was a common problem and something that can be fixed by completely uninstalling and reinstalling.
geposted Tue 10 Nov 09 @ 1:20 pm
well if you have time come to the chat on the support page I'll see what i can do.
geposted Tue 10 Nov 09 @ 1:44 pm
Thanks! I'm there waiting. Tried earlier too so i may have two sessions.
geposted Tue 10 Nov 09 @ 2:15 pm
well i tried to talk to you on there but you arn't responding.
geposted Tue 10 Nov 09 @ 2:20 pm
Thank you Jason for your excellent support on both issues i experienced !
For others who may experience the same problem try installing 6.03
geposted Tue 10 Nov 09 @ 2:58 pm
its no problem at all :)
For other people with this issue, sometimes you have to kick itunes in the rear to get it work correctly. Here is how
1. hold down option while you launch itunes
2. choose the lib file you want to load.
3. download 6.03 from your download center
4. launch
9/10 times this will fix problems with itunes not showing up in vdj
4. launch
geposted Tue 10 Nov 09 @ 3:32 pm
