... the icon only jumps once and nothing happens
geposted Tue 10 Nov 09 @ 11:10 am
try removing the plist file
geposted Tue 10 Nov 09 @ 11:15 am
theres nothing in the folder
geposted Tue 10 Nov 09 @ 11:22 am
where is the plist file?
geposted Tue 10 Nov 09 @ 11:31 am
You might be better off to grab a copy of appzapper and remove vdj then reinstall it.
geposted Tue 10 Nov 09 @ 12:18 pm
I've just installed it for the first time on my Mac Pro and it works fine!
geposted Tue 10 Nov 09 @ 1:08 pm
i unistalled with appzapper and i have the same problem... im running 10.4.11
geposted Tue 10 Nov 09 @ 1:15 pm
Attention
Please note Tiger is no longer supported by VirtualDJ, If you must use tiger we recommend running an eariler version or updating to Leopard or Snow Leopard.
geposted Tue 10 Nov 09 @ 1:41 pm
ok.. well can someone please upload 6.02 ASAP?!?! i have a gig tonight and i erased it!!!
geposted Tue 10 Nov 09 @ 4:56 pm
Done check your download center
geposted Tue 10 Nov 09 @ 5:28 pm
thanks for the help... how much is the leopard update?
geposted Tue 10 Nov 09 @ 10:31 pm
Not sure for the USA, check the Apple website
geposted Wed 11 Nov 09 @ 1:00 pm
