Iam So happy i stayed with such an amazing software thank you so much virtual dj staff :) XD !!!!!!!!!!!!!!!!!!!!!!!!!!
geposted Tue 10 Nov 09 @ 1:34 pm
timecode?
geposted Tue 10 Nov 09 @ 1:37 pm
dj-in-norway wrote :
timecode?
timecode?
yup no more drifting on timecode now virtual dj is better than serato hands down its only a matter of time before vdj becomes industry standard !!!!!
geposted Tue 10 Nov 09 @ 1:41 pm
What timecode engine are you using?
geposted Tue 10 Nov 09 @ 1:43 pm
thats good to hear ;)
geposted Tue 10 Nov 09 @ 1:51 pm
Let's all contribute to the Rise of Virtual Dj then :D
so your saying NO Problems at all, it Works just like à real vinyl Record?
geposted Tue 10 Nov 09 @ 3:05 pm
Should work just like using vinyls ;)
Using timecode is a bit of tweaking, but seems to work perfect for most..
Since VDJ is open standard to any soundcard etc, versions will continue to improve for those who may still have issues.
geposted Tue 10 Nov 09 @ 3:21 pm
Hello folks ..
i think the drifting Problem is over but the Beatmatch Problem is still here?
The BPM are ok no up and down but when i Beatmatch, for Example (Sync) after 20-30 Secounds the Beat is going to Fast oder to Slow. I think its not using the BPM form VDJ, VDJ use the TTs Pitch...
The most German People didin`t have this Problem ... only me :).
I hope anyone here can help me ...
Maxstell ...
(sry 4 my Englisch)
Maxstell ...
(sry 4 my Englisch)
geposted Tue 10 Nov 09 @ 5:34 pm
You mean the BPM is not constant for you, and other at german forum does not have the problem?
Could it be your turntables? NO turntables are perfect, it has wow and flutters in the rotation.
If you use relative mode in VDJ, does it get better?
geposted Tue 10 Nov 09 @ 5:38 pm
I dont read anything in the German forum...
Hm the Turntables (Reloop 2000 Mk2). I dont know... i only got this ones.
I play in Relative and smart relative and Absolut.. ervertime the same Problem.
Yes when i bend it to the right place, then its going after 20-30 sec. out of the Beat. But its Only in the Waveform.
i got one Video for demostration:
geposted Tue 10 Nov 09 @ 5:45 pm
what do you mean "only the waveform" ?`
Does the sound stay in sync, but the waveform drifts ?
And at your timecode settings, your 2 waves are a little bit "distorted".
You need to try get more PERFECT circles, and perfect waves..
Adjust the knobs under the circles to get more perfect circles.
Also, try the new SMOOTH option in VDJ 6.03
geposted Tue 10 Nov 09 @ 6:30 pm
Im in the Timecode section where do you go to switch timecodes from v4 to v5 or v6
geposted Tue 10 Nov 09 @ 6:42 pm
No the Beat is going out of Sync. In the Waveform and the Sound.
In VDj is see smooth : checked he going with the Turntables and unchecked the Pitch is stable.
I try a lot of things, can you show me the Perfect circles for Timecode with Virtual Vinyl ?
Thanks .. Maxstell
Thanks .. Maxstell
geposted Wed 11 Nov 09 @ 9:51 am
No drift here, I love it.
VDJ PRO 6.0.3
VDJ TC Engine 5
VDJ TCV 5
Smooth Pitch option activated.
VDJ Team, now we are talking, great job guys;
THANK YOU
VDJ PRO 6.0.3
VDJ TC Engine 5
VDJ TCV 5
THANK YOU
geposted Wed 11 Nov 09 @ 1:33 pm
You guys are getting me excited. First thing I'll do when I get home tonight...
This might be one of my best DJ days.
geposted Wed 11 Nov 09 @ 2:55 pm
So how do we switch between different timecode engines....
geposted Wed 11 Nov 09 @ 4:22 pm
I would like to know also
geposted Thu 12 Nov 09 @ 11:36 am
It's in the timecode config.
There is this, Vinyl: then at the side of that there is a drop down. Hit that and you will see all the timecode engines.
geposted Thu 12 Nov 09 @ 11:49 am
