Hi All,
I'd like to make two changes to my RMX mapper:
1. I have noticed since upgrading to 6.x that the jog wheels on my RMX are less responsive. How can I change the speed of the jog wheels - scratch off...
2. I want to assign the RMX crossfader as the video crossfader as I am using the controller in external mixer mode and currently do not use the RMX crossfader.
Cheers,
Roy
Cheers,
Roy
geposted Wed 11 Nov 09 @ 4:33 pm
OK,
Had a quick play with the mapping tool - but without the RMX connected (it's packed away)
I chose:
Key: CROSSFADER
Action: video_crossfader_link
Would this be correct?
Roy
I chose:
Key: CROSSFADER
Roy
geposted Wed 11 Nov 09 @ 6:39 pm
You can adjust the jogwheel sensitivity in CONFIG -> Options in VirtualDJ v6
Also, set Crossfader to Disabled and under the Video tab, tick Video crossfader linked to Audio crossfader
geposted Wed 11 Nov 09 @ 6:40 pm
That, of course, would be easier...
Thanks,
Roy
geposted Wed 11 Nov 09 @ 6:44 pm
