Hey guys!!
I'm now using timecodes with vdj software and i found a sound distortion "music sounds like underwater" so i'm not sure if this is a latancy? or sound card? matter or has something to do with setting up the right sample rate or bit rate? does it need to be setup to 16-bit rate or 24-bit rate on the pc's sound setup panel?
I have a pc toshiba satellite a305, windows vista intel(R) core(TM)2 duo CPU, T6400 @ 2.00GHz, 3.00GB of RAM
32-bit operating system //// and i'm using an Audio 4DJ interface made by native instruments
I will appreciate if somebody can help me with any tip on how to make the right setup!
Thank you guys!!
Thank you guys!!
geposted Wed 11 Nov 09 @ 5:56 pm
alex079 wrote :
Hey guys!!
Thank you guys!!
Thank you guys!!
Brilliant question because I have the same audio interface using timecode vinyls and get the same result when using my TCV the sound is muffled by the timecode quality thats why I have been using a single timecode so I can switch over when vinyl control is not needed. I would definitely love to know if latency can be a factor here and if I should use ASIO4ALL instead of the ones provided?
geposted Wed 11 Nov 09 @ 8:20 pm
