Rookie In Da House!! I'm sure this has been posted before; I searched but couldn't find a similar problem, so here it goes. My controller is on back order, so I've been practicing with just my laptop mouse pad. I have my sound card connected to my amp. I had been practicing for over 2 hours; I had a tune playing on deck B, loaded the next tune on deck A. When I clicked play to start deck A, it would not play. I reloaded the tune, loaded another tune, etc., but nothing I did would start deck A to play. I finally had to shut down the program and restart it. Both decks worked fine after that. This is the second time this has happened to me. Is this something I'm just gonna have to live with, or is there a fix for this problem?
Oh Sorry: Using a Toshiba Satellite L515 with Intel Pentium dual-core (2.10 GHz), 4GB Memory, 320GB hard drive; a Maya44 -USB sound card, and I'm running VDJ version 6.0.2. Anything else?
geposted Wed 11 Nov 09 @ 8:01 pm
Sounds like maybe the usb got shut off and restarted. Check to see that your usb settings are correct in windows ie. shutdown usb (powersaving).
geposted Thu 12 Nov 09 @ 7:57 pm
