Should I be bumping the gain up in VDJ, it normally stays at 0db
I have the Auto gain/remember feature turned on
Any suggestions
Any suggestions
geposted Thu 12 Nov 09 @ 3:42 pm
I would not play with the software gain too much. If you feel you need more control, I suggest an external EQ like the Behringer 1502.
geposted Thu 12 Nov 09 @ 3:46 pm
Hi mate
You should only need to adjust the gain to provide a match between the two tracks you are playing. Most of the time very little adjustment is needed. The automatic feature can sometimes make mistakes if the track has a long quiet intro but most of the time its ok. Use your own judgment and check tracks on PFL/CUE before you use them and adjust if required.
Daz
Daz
geposted Thu 12 Nov 09 @ 3:50 pm
Great, Thanks!
geposted Fri 13 Nov 09 @ 6:27 am
Also, it's sometimes better to be in the - rather than the + for the software gain.
If you go too far into the + you're at risk of clipping :(
geposted Fri 13 Nov 09 @ 7:19 am
