Could you tell me the value to encode in these shortcuts:
(letters are the one I choosed)
"G" => Set gain to 0db
"Shift+G" => Increase gain (+0.1db)
"Alt+G" => Decrease gain (-0.1db)
Thanks in advance.
Thanks in advance.
geposted Wed 04 May 05 @ 2:08 pm
I use these
Ctrl for deck one and alt for deck two up for increase the gain +0.1 and down to decrease the gain -0.1
CONTROLS: ctrl/alt + up/down
ACTION: gain
VALUE: 5 or -5
DECK: deck 1/deck 2
/// All this will create gain plus 0.1+ per click
ctrl + down = deck 1 - 5 gain
(controls = alt + up) (Action = gain) (value = +5) (deck = deck 2) = deck 2 = + 1 gain step
Short description:
If you want to raise the gain on deck one +0.1
Add a gain control then a new window will popup
it should look like this...
CONTROLS: Ctrl + up (my own controls)
VALUE: 5 (makes the gain step up 0,1 steps)
DECK: Deck one (makes the action on deck one)
i do not know if u will be able to reset the gain to 0.0, reset only makes them reset to its start value i belive...
ACTION: gain
VALUE: 5 or -5
DECK: deck 1/deck 2
Short description:
geposted Fri 06 May 05 @ 3:23 pm
i did not read your post fully but here´s the shortcuts...
reset Read last post...
Increase Gain on default deck (the active one)
Will be --->SHIFT + G +5 (or just 5) on default desk
And decrease gain default desk (the active one)
Will be --->Alt + g -5 on default desk
I strongly recomend to use ctlr and alt as deck1 and deck2 it helps alot
ctrl + up = gain + 0.1 on deck 1
ctrl + dwon = gain - 0.1 on deck 1
alt + up = gain + 0.1 on deck 2
Alt + down = gain - 0.1 on deck 2
geposted Fri 06 May 05 @ 3:32 pm
