Hi everybody
I heard that we can connect headphones on the speakers "Hercules XPS 2.0 30", is that means that it can work like an extern sound card ( "Hercules muse pocket lt" for example ) for my "Hercules DJ control MP3" ??
geposted Fri 13 Nov 09 @ 7:21 am
Hi mate.
I hope I am anderstanding your question.
The Herc MP3 is a controller only so yes you need to connect an external sound card or have one in your PC./laptop
(check that the version of VDJ that came with your unit lets you use external multi channel cards as I dont think the LE version will allow this).
The MK2 has a biult in card that provides an output to connect to an amplifier (for your speakers) and a headphone socket.
The XPS 2.0 30 speakers are line input only (analogue) they do not have a sound card built in but you can run them from the headphone socket on your laptop. They also have a headphone socket but this cuts off the speakers when you plug into it.
Daz
Daz
geposted Fri 13 Nov 09 @ 8:55 am
