Im sorry if this is not the place to post this question if it is im sorry... Well this is my problem when i mix videos i get cracking sounds only when i do videos and i have tried every setting possible sfe mode and overclocked are not checked done everything i could think of. but i jsut found out what my problem is when i minimize the skin that i use all the crackling goes away is there a fix for this?
Intel dual core t7200 at 2ghz
2 Gig Ram
ATI Radeon x1400
2 Gig Ram
ATI Radeon x1400
geposted Fri 13 Nov 09 @ 9:42 am
I would first suggest optimizing your system (i.e. disabling whatever is not needed), as explained in this document:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
You can also use that cool little application called Game Booster (http://www.iobit.com/gamebooster.html)
Next, play around with the Rmx's ASIO buffer size until you find the right setting for your computer:
- Before launching VDJ, go to the Rmx Control Panel, and switch to ASIO audio mode.
- Set the ASIO buffer size to 480 (10 ms)
- Launch VDJ, use it for a while and see if this makes a difference. If not, raise or lower the buffer size and repeat until you find the right setting.
geposted Fri 13 Nov 09 @ 11:20 am
