Dear all.
I want to use the Mic, however I do _not_ want the system to dim/lower the music when mic is on.
I have searched and haven't found any buttons nor posts in the forum helping me with this problem.
System is VDJ Pro on a QuadCore AMD with a Hercules RMX Console.
Thanks for your help :-)
Kindest Regards
Freedom, Denmark
Kindest Regards
Freedom, Denmark
geposted Fri 13 Nov 09 @ 3:34 pm
VirtualDJ does not have a function to auto fade the music on MIC.
are you using a hardware mixer?
are you using a controller??
what model is it??
then we could help you..
what model is it??
geposted Fri 13 Nov 09 @ 10:48 pm
Thats not what he is lookin to do, he wants to not use the Talkover function on the Hercules RMS which lowers the music volume while talkin on the mic.
geposted Sat 14 Nov 09 @ 4:08 am
In the Hercules RMX control panel there is the option to alter how much ducking happens when using the mic. :-)
The panel can be opened by clicking on the icon on the Taskbar or from the Startmenu. ;-)
geposted Sat 14 Nov 09 @ 4:12 am
In the RMX counsel there is a talk over option, untick it.
geposted Sat 14 Nov 09 @ 10:07 am
Hey
Sometimes there are so many trees that I cannot see the forrest! I am used to FutureDecks Pro, where all these settings can be changed in the software.
Thanks all for the help.
Cheers, Hans-Henning
geposted Sat 14 Nov 09 @ 4:09 pm
