Hello. I'm new to this software, and have a few questions about the software. First I would like to know how to empty the deck from a file that's in the deck? And also is there any "Crossfade" adjustment?
Dodie
Celebrate Disc Jockey Service
Dodie
geposted Fri 13 Nov 09 @ 4:08 pm
Hi Dodie,
Some skins have an unload button, not sure if the default one does.
Have a look in the skin section for Vmix5.4, it definitely has an unload button on the third player window from the right. The skin is 1280 x 800 but I'm not sure if it will work fully with vdj 6 as i was developed for 5.2
Regards
Keith
Regards
Keith
geposted Fri 13 Nov 09 @ 4:15 pm
On second thoughts, why would you need to unload a deck anyway unless you were seriously short of RAM. I think most of us just replace the track on the deck without unloading the other one first?
geposted Sat 14 Nov 09 @ 5:08 am
If the skin you're using doesn't have an unload button, you can always right-click on the pause button for >2 seconds to unload it.
Check Config/Options - there's a Crossfader setting there that changes it's curve.
geposted Sat 14 Nov 09 @ 7:50 am
