Hi,
I have all my aplle lossless files 15.000 with embedded in the file cover art.
I use Easy CD extractor for ripping and and Media Monkey for sorting and organising the files.
It would be nice to have Virtual DJ by default show the embedded in the file ID3 cover art.
Now I have to click on every file, select the ID3 cover artand VDJ makes a copy of the cover art and stores it into the same directory as the sound file.
Theremust be a smarter way then clicking 15.000 times :)
freek
freek
geposted Sat 14 Nov 09 @ 4:42 am
Ok, it is a 2009 issue but I had the same last month with flac and mp3 files. So I will reply and close the topic.
For FLAC files, jboerlage FLAC editor does the job.
https://virtualdj.com/addons/13224/VDJFlacTags.html
But for MP3 or any other file extension, I found a way to do it in batch.
The video shows FLAC files but when your read FLAC, change it for MP3.
[CLOSED]
geposted Sun 27 Oct 13 @ 7:57 pm
